Ga door naar hoofdinhoud
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
Continuous noise on the low side of the screen
For some time now, my MacBook Pro (13 inch, 2017) has been experiencing strange continuous noise in the bottom side of the display and a strange blue band when I open the screen.
Here are the pictures:
https://i.stack.imgur.com/4yuXY.gif
https://i.stack.imgur.com/Wvo0x.gif
Is dit een goede vraag?
2 opmerkingen:
I would plug in an external display to see if they are present on it to be sure. If not they you need a new displace assembly
door
Thank you. I'm using an external display for my daily work and I have no noise at all.
door
Voeg een opmerking toe
1 Antwoord
@Gregorio Pellegrino - Then you need a new display assembly MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and here’s the guide MacBook Pro 13" Function Keys 2017 Vervanging van de schermmodule
Replace a display compatible with a 2016 or 2017 model A1706 or A1708 MacBook Pro 13" Retina laptop. Includes the 2560 x 1600 13.3" Retina LCD Screen, Display Cover, Bezel, FaceTime HD Camera, Clutch Hinges, Display Daughter Board, Cable Spring Mechanism. Part #661-05096. Afbeelding
Product
$444.99
Was dit antwoord nuttig?
Voeg je antwoord toe
Gregorio Pellegrino zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 58
