Ga door naar hoofdinhoud
Reparatie-informatie voor de Sony Bravia 32" LCD TV. Uitgebracht in 2005. Modelnummer: KDL-21EX700.
20 Vragen Bekijk alle
My screen just started flickering rainbow colours,what's the solution?
My Bravia 32 inch LCD TV screen just started flickering rainbow colours on the screen without any picture, but sound is still intact. What could be the problem and what's the solution to this problem?
Is dit een goede vraag?
Score 4
7 opmerkingen
It's a TV not a Windows PC please
door
Hello, I have a similar problem
Any help please??
door
door
Sony Bravia 32 inch old model tv screen mother board damage
door
So that's what solution my tv
door
2 commentaren meer tonen
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
@prompat none of what your screen shows should be related to the T-con board. Remove the back of the TV and post some good pictures of all of your boards and the interconnect cables. This looks like a Panel error. See if you can get some close-ups of the driver boards which connect to the LCD via some very thin and fragile looking ribbon cables.
Was dit antwoord nuttig?
Score 3
9 opmerkingen:
The Service manual points toward the panel itself as well. What would make you think it's not the T-con board? Not challenging, rather wanting to learn.
door
Do I need a technician to do this? So I don't complicate things
door
@prompat If you don't feel comfortable opening up your TV you can certainly take it to a technician. That said, you don't need to really mess with anything to take pictures of the various boards and post them here. You would especially be looking for burn marks, or burnt components on the boards, and there are boards that are even on the edge of the Panel that you should look at and get pictures. But it's your choice completely.
door
That said, I'll open it up and take the close pictures after which I'll post them here for further guide
door
@billg66 I am assuming this was directed toward me? It's the outline that forms around the screens. Something like the outline on the right in purple. You would not get this "shape" with a failed T-con board. Remember the function on the board, scanning the rows and columns etc. To "draw" this shape would be a very unusual error. The rest could've been the T-con board but even with that, I would have checked the main board first.
door
4 commentaren meer tonen
Try a couple of resets first, if you haven't already.
Here's the Operating Instructions
Here's a link to the troubleshooting guide
Procedure for a Power Reset: (I would suggest that holding down the power button for a minute be added between the first and second steps)
  1. Unplug the TV power cord from the wall outlet.
  2. Disconnect all devices from the TV.
  3. Wait five minutes and then plug the power cord back to the wall outlet.
  4. Connect the first device to the TV.
  5. Turn on the TV again.
  6. If the problem still occurs, repeat the above procedure for each of the devices that you have connected to your TV. If it turns out that one of the connected devices is causing this issue, contact its manufacturer for support.
There may be a factory reset procedure you can try, but that erases any stored data you have.
Here's a link to the service manual
If resets don't help, a first guess is the TCON board, which is a small board in the lower center of the rear of the TV when the rear cover is removed. You did not mention blinking lights on the TV which would be significant, as these models use a blink code on their standby light for troubleshooting.
Second guess is the LCD screen itself. Section 3 of the Service Manual seems to indicate that in the triage section.
Score 2
1 Opmerking:
This procedures didn't fix it as well
door
My screen is flickering what solutions
1 Opmerking:
@mdfarhan you are not telling us what model it is nor are you giving us an exact description of what your TV is doing. We need more information in order to help you
door
Voeg je antwoord toe
Promise Patrick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 80
Altijd: 14,140
