Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie- en demontage-informatie voor de eerste generatie draadloze high-end oordopjes van Apple. Uitgebracht in oktober 2019. Te identificeren aan de modelnummers A2084 (linkeroordopje), A2083 (rechteroordopje) en A2190 (oplaadbehuizing).
Pair button doesn't work
I got some second hand airpod pros but i cant get the pair button to work. they charge and everything and they are genuine. i cant get them to pair for the life of me, please help.
edit: the white pairing button doesn’t turn on when i press the button
Is dit een goede vraag?
Score 5
4 opmerkingen
Are you following this guide?
https://support.apple.com/guide/airpods/...
door Deel
@yukamoran yes, the white led wont even show
door Deel
Did you solve it? I am having the same problem and just talked to Apple Support. They recommended to see the Genius Bar next week.
door Deel
One pair is not working
door Deel
Voeg een opmerking toe
9 Antwoorden
Filteren op:
Het nuttigste antwoord
When i had this issue i found a cheap case off amazon to pair with but here are the steps you can try to get them to pair,
Make sure your bluetooth is on when attempting to pair by holding down the button for up to 10-15 seconds if that does not work fully charge your airpods then open them up near any apple device with bluetooth on which should allow it to connect.
If this does not work what i did was buy a cheap case off of amazon to just pair them with the airpods themselves. this does work with all models but the case will be somewhat bad quality.
Hope this helped.
Link for the case : https://a.co/d/3QVUhEU
Was dit antwoord nuttig?
Score 1
Hi,
so my headphones are paired and working again.
Thanks to Edelgard at the OEZ Apple Store, my AirPods Pro are working again. I am not sure whether this is the solution but here is what happened. My headphone case was checked and tested with another pair of AirPods Pro. Ultimately, the decision was: the pairing button is broken. However, when I put my own headphones back in again the LED started blinking white again. I was then able to pair the case with my iPhone again.
So, if you have the same problem and another pair of AirPods Pro at and, give it a try!
Score 1
I have the same issue with AirPods Pro (gen1). I borrowed another case (but from airpods pro gen2), but they still wouldn't pair... So the case should be exactly from gen1?
Score 1
Reset the AirPods first (not sure if you already did that). Hold the back button while the case is plugged in until the LED flashes amber. Keep holding the button until it flashes white.
If the LED doesn't respond, then the button itself is probably broken. And that's not going to be easy (or probably even possible) to fix. So, I would recommend getting a new case.
I am not a 100% certain that the case for AirPods Pro 2nd Generation or AirPods Pro 2nd Generation (USB-C) works with AirPods Pro 1st Generation. You should probably check into that before purchasing the case.
Score 1
Everything is okay but they are not connecting with my phone I don't know why
Score 1
Use another case to pair them. Just borrow anyone’s case to pair them and don’t make the same mistake cause there is NO other way to pair and Apple will not help except Charge you $100 for a case or $250 for new ones
1 Opmerking:
What do yo mesn
door Deel
каробка не заряжается и если я положу наушники на каробку не выключается
Airport is not working and the power butten is also not working
you can try the following: keep the case on a charging cable to charge (the case should indicate that it is receiving power). Should the headphones have deeply run out of power put them in the case for 10 seconds take them out again and repeat this like two dozen times. A friend got their headphones to work again because in that brief moment of putting the headphones in, they received a bit of charge until eventually they had enough to register with the case again.
Voeg je antwoord toe
Charles Adamski zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 56
Afgelopen 30 dagen: 210
Altijd: 28,818
