Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
Wifi Cables broken near display. How can these be repaired?
The wires just fatigued and broke from the display being opened/closed over the years. Wifi was still kind working (very slow) until I took the wifi card out saw that all the wires were broken.
I have decent soldering skills. Just wondering if anyone has a proven solution before I make something up.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi
Most of the time these wires are fixable
Do you mean the little connector bits at the end(highlighted by the squares in your photo)
as far as I know you can just solder the cable back together(with it prepared for it)but if its the small connector that has fallen off the end ,you will probably have to crimp a new one on to get a good connection that works ad you can't let solder flow into the connector itself
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 3
10 opmerkingen:
The highlighted connectors are to indicate the which wires. They are broken at the location indicated, not at the connector ends.
All 4 cables have been broken. Any idea on how to identify which cable is which coming out of the screen assembly?
door
@fr3nch
You could use this listing as a diagram(linked below),however this would be quite difficult so I would recommend buying a new one
https://www.ebay.co.uk/itm/284255942537?...
door
@hellomacos
That is excellent! Thank you! I was looking for the antenna cables as a stand-alone assembly, but couldnt find them. Ill look into just getting a replacement instead of soldering. Thanks!
door
@fr3nch
Your most welcome!
please let me know if there's anything else I can help with:-)
door
@hellomacos - Replacing the assembly is the better answer for most people.
door
5 commentaren meer tonen
Voeg je antwoord toe
ECC zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 203
