Ga door naar hoofdinhoud
The Xiaomi Redmi 9A is a low-budget smartphone by Xiaomi released June 2020. It has a 6.53" IPS LCD display, a 13 MP main camera, a 5000 mAh battery, and runs on a Helio G25.
Why is my phone slow and freezing
Is dit een goede vraag?
Score 32
8 opmerkingen
why my redmi 9a slow and freeze ?
door
My mobile redmi9A is slow and freeze problem how to fix
door
Hi im Mohamed my phone slow help me
door
My very slow working
door
Yes my phone is very Lage and very slow open and app opening slow problem 😞 😞 😞 😞
Please solution
door
3 commentaren meer tonen
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Some apps and processes can run more slowly if there is not enough storage space available or if a faulty storage card is installed. Check your phone's storage in Settings > Storage, and delete or move files if your storage space is too low.
Regards,
Will
Was dit antwoord nuttig?
Score 9
Too often, the Redmi 9a crashes or freezes. Please remember that most of these crashes are caused by the storage being too full or an error in the software. What you have to do if it freezes or freezes is first try reloading your phone, then go to settings and reset all data. It's a shame that you have to back up your important data first, after resetting the data will be completely lost, you can try it for a few days, if you think your phone is still the same it means there is an indication of an error in the software, for the steps you have to take you have to do it. flash the entire cellphone, if you want to do it personally you must have tools and software files/firmware, you can search for it on the internet or tutorials on YouTube, IMPORTANT: flashing can cause the cellphone to completely die because the EMMC IC/Internal IC of the cellphone is weak, It would be good for you to understand about flash and EMMC ICs first
Score 2
MdFoysal0000
Rom kam ho gaya hai and slow ho gaya hai
Voeg je antwoord toe
faminizeslut zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 51
Altijd: 5,876
