Ga door naar hoofdinhoud
The Pixel 3a XL is the larger version of Google's third generation budget phones, and includes the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
17 Vragen Bekijk alle
Google pixel 3a xl
Is not coming on even after changing
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Charging, not changing, right?
We'll need more information to be able to help you, Jacob. Okay, first off, do you know for sure it's charging; is there some indicator like a buzz or a light when you plug in the charger?
Is this something that's just started recently? Have there been any changes to the phone lately, like new charger, system update, getting dropped or wet, etc?
Since a phone with a dead battery will behave just like what you're describing, we need to make sure it is indeed getting charged. So have you tried a different charger and a different charging cord? You're sure the outlet works, right?
You've checked the charging port for any dirt or obstruction? Cleaned it with a toothpick and some isopropyl alcohol?
Give some of that a try and get back to us with more information and I'm sure we can figure it out.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jacob Edwin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 80
