Ga door naar hoofdinhoud
Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
375 Vragen Bekijk alle
Replaced charging port, still rebooting
Yah so had a charging port panic full prs0 whatever you call it, i replaced the charging port, and nothing has changed, did i less up? Is it a bad part, is somthibg blocking the sensor? Please help, thabks guys (and gals)
Is dit een goede vraag?
Score 2
5 opmerkingen
Iphibe xs max
door
Nate dog, can you screenshot or copy/paste the text of the panic log so we can see what you see?
door
Yessir one moment
door
Jerry, do you have tellegram?
door
@natedawg22, no, I'm afraid not. I was suggesting posting it here so we can all see the text of the error message; there are several people on here who are very experienced in dealing with kernel panics who might be able to help.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
If the issue is the PRS0 sensor, that’s the pressure sensor (barometer). It has a pretty recognizable appearance on the charge port assembly. When I buy these, I generally make sure I get them from reputable vendors, or ones with a documented warranty or return policy. I have seen shoddy cables of all sorts, but testing in a known good housing, or with a known good charge port would be a good start.
If it still does this with a known good, charge port, then you may be looking at a board problem.
iPhone XS Max Lightning Connector Assembly Afbeelding
Product
$24.99
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Ok question, for the little hole where the sensor goes, any adivce? How do i get it in there? Should i glue it in? Should it stick by itself? What glue? Should i be carefull not to do somthing? Thx boss
door
Also does the port flexes/black sheet stuff have to blue glued diwn in anyway for me to test?
door
Did you use an original chargeport? And try to disconnect all flexcables except the on/off flex. If it restarts, add one flex at the time until you found the problem.
1 Opmerking:
Also where can i get an original flex cable?
door
Voeg je antwoord toe
Nate dog zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 272
