Ga door naar hoofdinhoud
Released in early 2015, the Canon PowerShot SX530 HS is a Wi-Fi enabled, super zoom camera. This camera weighs just under one pound. Identified by model number pc2200.
Camera has 'Memory Card Locked' on screen.
My camera suddenly came up with 'Memory Card Locked' on the screen. It is NOT the switch on the card itself, and I can't make the Menu select the Card Lock symbol that shows a key. My camera will not take pictures while it is locked! Please help. Thanks.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Try the memory card on another camera,
  • if it works (or you use another known to work card and confirm the problem stays the same) the problem is with your card reader:
  • ensure the camera's switch is not stuck and the inside of the slot is clean, you can follow Flying Dutchman's tips from this post (if it helped you solve your problem, please feel free to leave a feedback to the author)
  • If it doesn't, it could be it's corrupted or the filesystem may be incompatible, backing up everything on it and formatting it with your camera should solve the problem
Hopefully you found this useful,
cheers
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 766
