Ga door naar hoofdinhoud
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
412 Vragen Bekijk alle
Buttons unresponsive or require extra pressure
I have a 3DS XL and there are a few buttons that require extra pressure or don’t work at all but I can hear them clicking so I know they are not stuck, left on the dead requires extra pressure, down on the dpad doesn’t work at all, unsure if the x button works though, I have cleaned the pads to eliminate dirt but I fear it may be the buttons on the board itself
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Clean the Circuit Board and the Rubber Buttons
The best way to clean circuit board and the rubber buttons is cotton + alcohol. Never use water.
After cleaning both the circuit board and rubber buttons you should check if the buttons are working before proceeding. The reason is; cleaning the circuit board and rubber buttons most of the time solve the issue.
If it's working. Welldone!
Regards,
Will
Was dit antwoord nuttig?
1 Opmerking:
That’s the problem I’m running into, I have cleaned them but they aren’t using rubber membranes, they used actual buttons on the motherboard and I am trying to find the best way to clean those as the contacts don’t seem to be as good as they used to be
door
Voeg je antwoord toe
Nascar1243 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 691
