Ga door naar hoofdinhoud
My phone display shaking and flickering after dropping
My phone display is shaking up and down (like a glitch) and some parts of the display are black mainly at the corners. I could also see some cracks on the edges of the screen.
What could be the problem and how to fix it?
Is dit een goede vraag?
Score 3
2 opmerkingen
شاشة هاتفي بها حبر ازرق وبنفسجى اثر خبطه على الشاشة وكانت صغيره مثل وضع أصبع وبعد ذلك زادت مساحتها بعرض وطول عقلتين أصبع ماهوا الحل بدون تغير الشاشة
door
@Mohamed esawy
The is no other option.
The screen will have to be replaced as it cannot be repaired.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi
When this sort of thing happens it usually means that the display is internally damaged but I have had luck reseating the connector on the board
But because your display has cracks in it it will most likely need replacing
Here’s a guide in replacing the screen for your phone
https://m.youtube.com/watch?v=h9uETgnfzD...
Also here’s the part you will need too
https://www.ebay.co.uk/itm/255668681891?...
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 5
1 Opmerking:
I'm already replace my display but rather display is automatically touched why is this like ?
door
Voeg je antwoord toe
Ajeeth kumar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 73
Altijd: 629
