Did a complete shell swapp and the lcd not working
I did a complete shell swapp and lcd not working I went over all my work it's shows its on but don't see a image I replaced the lcd and it's still doing the same thing help
Is dit een goede vraag?
Have to echo @strongbow's suggestion; there are only two connectors for the LCD, so unless the motherboard got messed up during your swap, it's got to be one of those. I believe this is the one he's referring to.
And the other one is here, as you know.
Most common mistake I've seen is not getting that wide ribbon cable fully seated. Lift the latch and make sure both of the little tabs on either side of the ribbon cable are butted up even against the front of the connector where it slides in. While holding it in place, lock down the latch. Make sure the other connector is also in all the way and even on both sides.
Before you button it back up, reattach the battery and try it again to verify whether it works or not.
Was dit antwoord nuttig?
Looking from the back, on the left side below the card reader is a small ribbon about 5 or 6 mm wide. Remove it then put it back in making sure it is all the way in and fully seated and then try it,
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 50
3 opmerkingen
When you say you replaced the shell, it may be helpful to know exactly what that entails, or what parts you needed to remove or disconnect, since the housing isn’t one solid piece.
I would also check and see if you’re getting an image, but backlight isn’t on. If you shine a flashlight at the display can you see anything?
door Alisha C
Ummmm ok meaning I had to take apart everything I swapped the whole shell front and back everything had to come off
door Raymond
The backlight turns on just no picture at all
door Raymond
