Ga door naar hoofdinhoud
The Chevrolet Cruze is a compact car made by the Chevrolet division of General Motors. The Cruze was first released in 2008 with a front-engine, front-wheel-drive layout.
27 Vragen Bekijk alle
2013 chevy cruze, my front window on driver side won't roll up or down
I have a 2013 chevy cruze, my front window on driver side won't roll up or down
Is dit een goede vraag?
Score 1
1 Opmerking:
If no one here is an expert on Chevy Cruze troubleshooting, your best alternative as a diyer before resorting to dealer or repair shop $ervice$ would be searching for Chevy Cruze forums for owners more likely experienced and helpful with specific info. Basically this problem breaks down to; fuse, window switch, wiring, power window unit and window mechanicals.
door
Voeg een opmerking toe
1 Antwoord
M A check the switch or the motor. See if you have power on it. I attached the GM diagnostics for this power window.Power Window Diagnostic It's really overboard and goes into a lot of depth. Also, check the part of the SM that shows the repair of the switch and the motor.Power Window Repair Of course you also want to check the wiring.
Was dit antwoord nuttig?
Voeg je antwoord toe
M A zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 116
Altijd: 1,712
