Ga door naar hoofdinhoud
Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
Broken Home Button SE2020
Hello Everyone,
The home button broke on my iPhone SE2020. It’s got a little crack in it. It doesn’t work, and a second on screen button appeared.
I cannot find a home button replacement. They do have replacement button for the 7/7 Plus, 8/8 Plus. Will this work on my phone? If this doesn’t work, is there any other fix? I’ve replaced batteries before, so I’m not a complete novice.
Regards,
James
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Example of replacement button
https://www.ebay.co.uk/itm/174249012020?...
Was dit antwoord nuttig?
Het nuttigste antwoord
You can not replace the home buttons past the 6s because Apple pairs them to each device and they are not real buttons.
Score 2
5 opmerkingen:
If I were to replace the button would it have any functionality at all? I don't use the touch id features. I just use it like the old fashioned way to get the menu open. Thank you for the prompt reply!
door
It will be completely dead. You cannot even use it as a button and sadly the only fix it to take it to Apple. @uberflexer
door
@uberflexer yes, you can buy an aftermarket button that gives you the click/home function but not fingerprint.
Look on ebay or Google it. The iPhone 8 one might be compatible but make sure first.
door
Thank you Nigel & Duck!
door
@uberflexer No problem, good luck
door
if you replace the home button with a 3rd party, you will lose Touch ID capability. the only way to retain Touch ID is to have Apple do the repair and it costs (so i'm told) upwards of $300.
you can DIY the replacement. the 7, 7+, 8, 8+ and SE2020 all use the same home button.
yes you can get them on ebay, but i've stopped getting parts from there and switched to regular vendors because of better post sales support.
ifixit sells buttons - iPhone 7/8/SE 2020 Replacement Home Button
so does mobile sentrix - https://www.mobilesentrix.com/home-butto...
i've had a lot better success with the JC brand (mobile sentrix) than i have with the HX (ifixit) or YF (ebay) buttons, but that could just be my own experiences
Replace a home button compatible with the iPhone 7, iPhone 7 Plus, iPhone 8, iPhone 8 Plus, and iPhone SE 2020. Afbeelding
Product
$23.99
Score 1
Voeg je antwoord toe
James Bradway zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 92
Altijd: 3,815
