top volume button isn't working
the top volume button is stuck. is there any way to fix that?
Is dit een goede vraag?
You'd have to remove the screen and maybe, depending on location remove the motherboard too. Then remove the plate behind the buttons to remove and clean them and the opening for the buttons. Unless the area around the buttons has been damaged. If you haven't removed a ipad screen before go real easy as there's a risk you'll break it.
Was dit antwoord nuttig?
Thank you. Definitely helpful but I’m not that tech savvy. Have a great day!
Check your iPhone's volume settings (sound settings) to make sure that volume buttons aren't disabled. To do this: Open the Settings app. Tap Sounds & Haptics
Regards,
Will
Thank you - will try that.
my power button is not working well, it is mostly stuck. Can this be fixed?
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 27
Altijd: 589
