Ga door naar hoofdinhoud
What hardware would cause stuttering?
I’ve noticed tiny stutters when moving the screen and frame drops on certain games on the Series X. If it was due to a faulty component, what component might that be? SSD? CPU/GPU? And where would you get such replacement parts? Could it be just the game itself? Could it also just be a faulty console update?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Nobody knows, Xbox is a fully encrypted and un-debuggable unit in retail mode.
Are you sure it is not just bad game coding? Does the issue happens on the same game with every Xbox?
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
I don’t have a spare Xbox Series X to try. Some games run better than others. However there are issues with some games stuttering when you enter a new area which leads me to believe it’s an SSD problem. I replaced thermal paste so it can’t be an over heating issue. Not sure as well if it’s solely due to the fact I’m on 60Hz instead of 120Hz.
door
@kain05 Still sounds like expected behavior to me.
door
Voeg je antwoord toe
Kane zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 349
