Ga door naar hoofdinhoud
Model number: 20R1000RUS, Released in June 2019
13 Vragen Bekijk alle
Why does my power button blink 3 times?
i recently found my lost laptop. When i plug in my charger the power button flashes 3 times and then nothing happens from there.
Is dit een goede vraag?
Score 8
1 Opmerking
I have the same Issue with my Lenovo X1 carbon 6th. When I press the power button nothing happens. But when I plug in the AC cable the light on the back flash tree times. And there is some sound from the processor.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
For others reading this there are two power staus lights.
One is for the AC power located on the back of the computer.
The other one on the top right from the keyboard is the power on light.
Rick have you tried activating the emergency reset button.
This is located on the bottom of the laptop and can be activated by inserting a paperclip in the hole.
Here are the steps:
  1. Unplug power
  2. Find a thin paper clip
  3. Locate the Emergency Reset Hole on your laptop
  4. Press and hold the Reset Hole for ten seconds with the paper clip
  5. Power on
Was dit antwoord nuttig?
Score 13
9 opmerkingen:
Hello Mike,
I have the same problem with the same laptop brand.
Lenovo Thinkpad T480. I tried the reset method but nothing changed,
Maybe there is something more i can do to check for the problem.
I will apriciate if u have any other advice.
door
Hi @andreaq,
Some how missed your question.
Here is link to service manual:
https://download.lenovo.com/pccbbs/mobil...
(from page 44) Blinks three times:
• Three Blinks quickly: The computer is entering sleep or hibernation mode.
• Three Blinks slowly: The computer is in sleep mode.
Page 35 explains sleep and hibernation modes.
door
couldn't find the reset button. i just reseat the battery and it was successfully powered on.
door
Yes I found the reset hole in the back of laptop. I inserted the push pin, reset it and it worked for me. Thank you Rick for the post.
door
Thanks a lot, it saved my day as well.
door
4 commentaren meer tonen
Remove/disconnect both batteries. Remove RAM. Disconnect "button battery".
Wait more than 1min.
Reconnect all.
It worked for me.
2 opmerkingen:
Same symptoms, but pushing (with paperclip) and holding the reset button on the bottom of my Lenovo T16 fixed mine.
door
Emergency reset on bottom of the laptop will only work for about 3 times. So make backups and check for warranty. The second time this happens bring in for repair and demand them to fully boot regularly for about 4 or 5 times after reset.
door
Voeg je antwoord toe
Rick smith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 61
Afgelopen 7 dagen: 993
Afgelopen 30 dagen: 4,772
Altijd: 158,231
