Ga door naar hoofdinhoud
I think T-CON board is bad, but I don't know where it is
Samsung UN70TU6980FXZA 70" Class TU7000 LED UHD 4K . Has sound, backlight works, black screen (very dim blue glow from backlight). Figured it would be the T-CON board based on my research. I opened it up, no T-CON board (that I could see). I thought maybe the T-CON board is combined with the main board so I ordered that for $40, replaced it, no change in behavior. There are three skinny boards at the bottom, somewhere I think they were called "address boards". Are they the same thing as T-CON boards? Or is the T-CON on the flip side? The problem with the skinny boards is that they seem like they might be permanently connected to the panel, seems like no practical way to replace them, the ribbon cables are soldered/glued on I believe. Am I out of luck fixing this thing? It's only a couple of years old.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Mark Krueger you are correct. Your main board has the T-con circuitry on it. It is the same board. Let us know how you determined that the backlights are working. The safest way to test this on Samsung is to remove the cable from the power board to the main board. That would turn the backlights on. Since you already changed the main board (with the T-con board) it can be ruled out. You should also test the voltages on your power board where the backlight LCD's connect too. Let us know what that voltage is. The boards you pointed, to are the LCD driver boards and are not DIY replaceable since they connect via fine ribbon cables to the LCD panel.
Was dit antwoord nuttig?
Score 2
11 opmerkingen:
With the back cover removed I can visually see that the backlights turn on (and off) (plus when the room is dark you can see a very dim blue glow from the backlight leaking through the blacked LCD panel). I have done the "flash light test" as well.
With the backlight known to work do you still need to know the backlight voltage?
Are there other points/voltages to test?
door
@Mark Krueger Sounds reasonable with the backlights. If you do get the backlight but you do not get a picture than the issue is most commonly related to the main board. In your case you already replaced that, then the issue will be the panel. Of course, check the ribbon cables from the main board to the panel. Make sure there is not corrosion or tears etc. on those. There are no schematics for the driver boards so we may be out of luck on that. There should be a few numbers on those boards. Could you let us know what they are? We might find some information on those.
The only other thing, and I am going out on a limb here, is that the power board does not supply all the voltages needed to the main board. Check the connector for the values and measure those. Let us know what you get.
door
Thank you for the info.
I don't see any obvious issues with the ribbon cables, and the ones with sockets I had previously disconnected and reconnected to make sure they were seated well. I checked the voltages you asked for on the power supply connector (that feeds the main board):
Top row: 0v, 12.87v, 12.87v, 12.87v, 12.87v, 0v
Bottom row: 0v, 0v, 2.98v, 3.33v, 0v, 0v
I also attempted to measure voltages on the ribbon cable from the main board to the panel drivers. I could have made mistakes because the lines are so small. But Pin 1 to Pin 95 seemed to be 0 v, while pin 96 was 3.33v. The labeling said there were 96 pins total.
Here are some of the numbers I could see on the driver boards:
02 tpts E88441
K6608TP/K0487EV ZZ
FLD: RUNTK0487FVZZ-A1-L6S-0C2V
FLD: RUNTK0486FVZZ-A1-L77-010W
K6607TP/ K0486FV
31 TPTS E88441
FLD: RUNTK0485FVZZ-A1-L73-00VW
K6606TP/K0485FV ZZ
JE695R3HD7K
08Q45609 C
BN96-51823A Q01 2033
door
@Mark Krueger what do the ends on the LCD look like? The ribbon cables where the driver boards determined? Noticed any corrosion etc? Let's see if there is any data on those boards available.
door
I may not have understood your question completely, but the first picture shows an example I believe, I think that ribbon cable shown is pasted/soldered onto the driver board and the other side I suspect wraps around to the actual LCD panel (I have not taken the bezel off or taken off the "layers" on the viewing side of the TV). Everything that I have inspected on the back side looks undamaged as far as ribbon cables, capacitors, etc. as far as my untrained eye can tell, I was unable to find a "smoking gun".
door
6 commentaren meer tonen
Voeg je antwoord toe
Mark Krueger zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 70
Afgelopen 30 dagen: 240
Altijd: 2,657
