Ga door naar hoofdinhoud
Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's Arm-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
175 Vragen Bekijk alle
not sure if it is a MacBook Air2020 Early or Late model.
just looking to confirm the replacement part when I add the part it tells me it is not compatible with my laptop here is the model and sn:
model is A2179
sn: C02D9AKKMNHP
not sure if this is an early 2020 or late
Thank you for your help
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Based on the model number given, this is an Early 2020 MacBook Air.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you, I assume you are certain. and yes those are the numbers on the back or laptop. Thank you again
door
Het nuttigste antwoord
As @guardian10 has said, your model corresponds to the Early 2020 model.
2020 was when the switchover from Intel i3/i5/i7 processor to Apple M1 processor happened. The Early 2020 model still had an Intel chip, while the Late 2020 version now carries the M1 CPU.
So you've got an Intel chip in yours - not that there's anything wrong with that. :)
Full disclosure: I currently work for Intel.
Score 2
1 Opmerking:
thank you for the information.
door
Voeg je antwoord toe
Richard Coit zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 616
