Car shut off while coming to a stop.
Everything was put in new. 02 sensors, mas air flow sensor. Everything. But code stated 02sensor bank 1. Plz help thank you.
Is dit een goede vraag?
If your car is dying completely when coming to a stop a common cause is the gas to air mixture is too rich meaning your engine is not getting air. Try to locate the Air filter in the engine bay of your vehicle and spray it out with an air compressor or better yet just replace the filter.
Was dit antwoord nuttig?
thank you for the response. I have change everything but for some reason i keep getting code p0131. 02 sensor was changed and nothing
If you changed the 02 sensor then you may want to check the wiring for the sensor. If you find no faults with that then there is the rare chance that the new sensor you bought is faulty, it happens.
Checking the alternator's output could be an excellent first step in troubleshooting this issue. If the car still shuts off while starting and idling, then check 5fnyf6h53mb042819 pilot exl 2021 vin honda for loose connections or corrosion on the battery terminals or the battery itself. Your vehicle may have developed an electrical problem that could shut it off while you're driving.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 216
Does the vehicle start again when you let off the brake?
door Ferryman
No. The car shut completely off and I am able to turn it back on.
door Hunter K
