Ga door naar hoofdinhoud
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
Can I use a ipad 2 battery on ipad 3
I have ipad 3rd gen it's battery is dead
I also have 2nd gen ipad can i use the battery on 2nd gen for the 3rd gen.will it work properly
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Unfortunately, you're off by one generation. The batteries for the 2nd and 3rd gen iPads have different part numbers, connectors, voltage, form factor, and vastly different mAh ratings. The 3rd and 4th gen iPads do use the same battery, but the 2nd and 3rd aren't interchangeable.
Gold star for attempted reuse, though!
Here's a link to iFixit's battery that's made for your 3rd gen.
iPad 3/4 Battery - iFixit Store
Good luck with your repair!
Replace a battery compatible with 3rd and 4th Gen iPad models A1416, A1430, A1403, A1458, A1459, A1460. Part #616-0593, 616-0592. Battery model A1389. 42.5 Watt Hours (Wh). 3.7 Volts (V). Afbeelding
Product
iPad 3/4 Battery
$39.99
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Z17 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 291
