Ga door naar hoofdinhoud
Bose's consumer range of active noise-cancelling headphones are called "QuietComfort".
My right side doesn’t produce sound but noise canceling works
My right side doesn’t work and when I move the cable at the base of the ear peace it sometimes cuts the sound how would I best fix this.
I’d rather not have to spend money on this no I don’t have much to spare
Ps. I got them used from a friend
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi
This one sounds like a dodgy connection
If you dismantle the headphones and look around for any dodgy or suspicious connections ,try reseating them if they have a connector,if not try reflowing them with a soldering iron and if you see a worn cable try putting some flux on it and flowing some fresh solder into it to help restore the connection
If the damage looks bad or if any bare metal will touch each other I would recommend replacing the part
If you need any help please let me know
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Atticus Dillow zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 200
