Ga door naar hoofdinhoud
Reparatie- en demontage-informatie voor de Logitech MX Anywhere 2S draagbare draadloze muis. Uitgebracht in 2017 en identificeerbaar aan modelnummer 910-005151, 910-005133, 910-005152, 910-005153 of 910-005154.
My right click hold does not keep the hold, it stutters
The title basically tells it, when I hold down my right click it does not keep the hold, it instead kinda flickers the right click, if that makes sense.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi
It sounds like the button it your mouse needs some help!
First I would try taking it apart and getting some isopropyl alcohol and cleaning it with a tooth brush to remove any corrosion or debris
If that doesn’t work I would replace the button within one that has the same specs(same height,depth,width,button type…)
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
What parts inside of the mouse should I try to clean? I went in with a few dabs of isopropyl but I don't think it did the trick. I don't own soldering irons, iron and to buy a new part I think I should just buy another mouse.
door
@Eric Nguyen
There should be two buttons inside of your mouse
Try cleaning the one that isn’t working:-)
door
Voeg je antwoord toe
Eric Nguyen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 31
Altijd: 1,150
