Ga door naar hoofdinhoud
Released September 20, Apple's flagship 2019 smartphone features a 5.8" OLED display, a triple-lens rear camera, and greatly improved battery life. Successor to the iPhone XS.
iPhone 11 Pro Screen Removal
If you don't have a hot plate for screen removal, could a glass cooktop on low heat be a viable substitute? Or would that just destroy things?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
In my experience, heat is not necessary, but can be helpful on these displays. A suction cup and some force is generally sufficient.
As was previously mentioned the iOpener tool would fit the bill, but if that’s not an option, I have been known to use “heating pad” type alternatives. Rice, barley or oats in an old cotton sock + a microwave would serve a similar purpose. Although these contain some moisture, so I advise caution when employing this method. Or encasing in shrink wrap or a ziplock bag before applying to the phone.
Was dit antwoord nuttig?
Score 4
Hi Tony,
I'm not clear on why you feel you need a hot plate for removing the screen, but I'd be leery of using a cooktop, especially when a hair dryer will work suitably instead. The iFixit iOpener is pretty inexpensive and will do the job, as will a hot air gun if you have one. Here in the US, you can pick one up at Harbor Freight for about $17, but you do have to be a bit careful with it, as you can overheat an LCD or OLED display with them and ruin them that way.
No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries. Afbeelding
Product
iOpener
$24.99
Score 2
Voeg je antwoord toe
Tony Stark zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 269
