Ga door naar hoofdinhoud
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
A1286 won't turn on - black screen
A1286 won't turn on - black screen, have reset SMC, power light on
MacBook Pro A1286. Removable battery and hard drive.
  • Battery charges fine. LED indicators show charge level. Power adaptor shows orange when charging, green when charged.
  • When turning on, power LED lights up, the chime can be heard, but nothing on the screen (no flashes, etc.). Keyboard backlight does not light up; caps lock key does not light up when pressed.
What I've tried:
  • Have reset SMC with and without taking the battery out first; charging cable responds with green light
  • Have tried holding Command-Option-P-R startup as suggested in another thread
Have plugged a HDMI cable in to a TV, but nothing shows
Can anyone have some solutions thanks.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sadly, your logic board has an issue. You'll need to pull the board to inspect both sides MacBook Pro 15" Unibody Mid 2009 Logic Board Replacement. You might be able to see a burn't component. Compare your logic board to the images here. If you see something take a picture or two and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
Bottom (what you see)
Top
MacBook Pro 15" Unibody Mid 2009 Logic Board Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
1 - 2 hours
iFixit Afbeelding
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Was dit antwoord nuttig?
2 opmerkingen:
Hi, thanks for you're replay, I've checked the logic board as you advised me to do but it looks fine and clean no brunt damage on it and I even washed in the ultra sonic wave machine to remove the water damage but nothing helps.I even tried all of the solutions and nothing helps.
door
@rampage47 - Water damaged? Thats not good you may just need to bite the bullet and get a replacement logic board, look online for the following part numbers per the given version of board:
∙ 2.66 GHz -661-5212
∙ 2.8 GHz - 661-5213
∙ 3.06 GHz - 661-5214
door
Voeg je antwoord toe
RAMPAGE zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 534
