Ga door naar hoofdinhoud
Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
USB-C Board Replacement?
Hello, has anybody replaced the USB-C Board on either of these MacBook Pros?
MacBook Pro, 15" Touch Bar, 4-port
(2019, Model A1990, EMC 3359, 15,3)
MacBook Pro, 16" Touch Bar, 4-port
(2019, Model A2141, EMC 3347, 16,1)
There isn't a repair guide available for either model that covers a USB-C Board replacement.
Thank you...
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi
If you follow this video here it will show you how to remove the logicboard
Here’s one for the 15" MacBook Pro A1990 2019 Logicboard Removal
Here’s one for the 16" Inch MacBook Pro A2141 Logicboard Removal - Liquid Damage
If you want to replace your USB-C ports you just need to remove the screws ether side of the port then they should just slide out
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 3
Het nuttigste antwoord
All USB C boards on these Pro models, from 2016 on, regardless of size, are similar in process.
Follow the 16" Guide for Battery Replacement, up to step 66. This gets the logic board out. Disregard anything after. Unless you also want to replace the battery while you've got it gutted.
After that, use T5 drivers to remove the screws holding in the USB C boards. Two screws per board.
After the screws are removed, you just have to pull them out of the top case. Et voila. Reverse process with new ones. Or clean the existing ones and reinstall.
Score 4
Voeg je antwoord toe
bobjohnston zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 58
Altijd: 1,664
