Model of the display of iMac 17 "
Hello, I wonder what is the display model iMac intel 17 ",
or models are compatible with this computer.
my display has vertical stripes of colors.
Is dit een goede vraag?
Look on the bottom of the iMac stand for this information.
UPDATE
To find out the LCD model (and manufacturer) of the display in your Mac , open a terminal window and paste the following code followed by enter:
ioreg -lw0 | grep IODisplayEDID | sed "/[^<]*</s///" | xxd -p -r | strings -6
This gives you e.g. the following information:
B133EW01 V0
Color LCD
The first line is the LCD model number, the second is the active color profile.
If you google the LCD Model number, you can find out more about your screen (contrast ratio, brightness).
For my screen (build into a 1st generation Macbook build in 8/2006) I get the following information:
Info about B133EW01 Screen Model
Was dit antwoord nuttig?
good answer +
There is a company in California called DT&T that you can send your computer to and they will check it out and if your display is bad it will run about $450 plus shipping to get it fixed. Now depending on if it is the display , as you have not indicated it was damaged, it could be the logic board. If that is the problem it would run about $365 plus shipping to repair.
You may consider buying the external video adapter for your model and barrow someones desktop monitor and see if it works fine. That will give you an idea where the problem is and if you have the space you could save a few buck and just use it with an external monitor until you have the funds to replace it. Don't just replace the screen because it is acting up. Make sure where the issue is first.
Here is the info on that company
http://www.dttservice.com/iMacintel.html
good luck
The problem I believe that it is of display, because I have an external monitor and the exit of video is correct.
thanks for the Link, I am going to prove luck. thank you very much.
sorry if the English is bad writing, I am Spanish and I write little that I know
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,366
