Ga door naar hoofdinhoud
Released in Sept, 2018 by OPPO
24 Vragen Bekijk alle
My phone is not turning on
Before 1 month ago my realme c1 phone was suddenly turned off then I go to for repair they changed the folder and it was working after 15 days it happened again and my phone has been turned off while charging time.
Since then my phone is still not on.
Can you help me।
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
2 Antwoorden
Try to press and hold the power button for few minutes and repeat this process and check if its works.
Was dit antwoord nuttig?
If there is lint in the charge port, the cable can't seat properly and this can prevent it from charging at all. VERY CAREFULLY use a pin or needle to check that the phone's charge port is clean.
Voeg je antwoord toe
THIS IS PAVAN KASHYAP zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 54
Altijd: 550
