Ga door naar hoofdinhoud
Repair guides and support for weed whackers, also known as string trimmers, weed eaters, edge trimmers or line trimmers.
87 Vragen Bekijk alle
How do I remove this trimmer head? Shakespeare Push-N-Load 3-Blade
The trimmer itself is a Stihl FS 40C, I cannot get the head to stop spinning in order to twist the Shakespeare head off of the threads. I can provide any additional information as needed. Thanks in advance!
Is dit een goede vraag?
1 Opmerking
Reviewed any videos like this one(?); https://www.youtube.com/watch?v=JFYextYI...
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
With the trimmer head on the ground, on top of the gearbox where the head is, is a hole. You put a bar in and turn the head until the bar locates in a groove inside. Or even a screwdriver will do. This locks the shaft from moving so you can unscrew the head. I think it’s a left hand thread if I remember correctly.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
man i was stuck...with the same problem...u got it figured out for me...i knew there was a hole somewhere...but reading ur response got me to look again...and there it was lol...Preesh
door
@ashleymcke89493 Glad I could help. 👍
door
Voeg je antwoord toe
Tyler zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 67
Afgelopen 30 dagen: 239
Altijd: 1,582
