Ga door naar hoofdinhoud
Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
iPhone xs max randomly bootloop when not in use
So my iphone randomly bootloop when the phone is not in use
This is the panic log :
"panicString" : "panic(cpu 0 caller 0xfffffff023ab1c98): \"i2c0::_checkBusStatus Bus is still in a bad state; last read status 00010110 int shadow 00010100 xfer 00000000 fifo 00000000 for device ad5860\"
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
This panic refers to an i2c error. Specifically i2c0. I2c is an electronics protocol which is used for inter chip communications. In the same device there may be several different i2c groups. In the XS Max, and most others iPhones, i2c0 includes some of the most fundamental components, most notably battery data is transmitted on this channel.
So new battery would be the first thing I might try. I would even double check the battery health option in battery settings to see if it’s reading that the battery needs Service.
We may also be able to get more information about the exact error with a bit more of the panic file.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks for the answer, ill test a few parts that maybe broken from the web that ive seen.
door
It would be better if you can add additional info from the panic string data. You can however check here to see all panic string data and their interpretation. Check bus status, I'm thinking it should be charging connector flex. One of the first prerequisite to try, test an OEM charging connector flex and see if it works.
1 Opmerking:
Ive read all the panic full and all the panic string is \i2c0. I don't know about the additional info you mean, can you explain it more? Thank u
door
Voeg je antwoord toe
Royce Valentino zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 17
Altijd: 2,310
