Ga door naar hoofdinhoud
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
580 Vragen Bekijk alle
Can you put a 2009 logic board into a 2012 MacBook Pro
Can I install a 2009 logic board into a 2012 Macbook Pro
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
So their are a few issues with attempting this. While both boards seem to have a similar layout for its standoffs, the 2012 board has several different ports for the camera, battery, Airport/Bluetooth, and Optical drive. It's also worth pointing out that if you're replacing a core component like the logic board, then you might just want to start looking for a new computer at that point as the logic board is pretty much the computer itself.
Was dit antwoord nuttig?
Score 1
Simple answer - No!
There are quite a few physical differences as well as cable connections which are different.
There really is no benefit putting an older logic board within a newer case. Why would want to do this?
Score 1
Voeg je antwoord toe
Braxton Sanford zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 28
