Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Vragen Bekijk alle
battery replacement for iPhone 4 shown on iFixit
I watched a video by iFixit on changing the battery. The girl in the video took off an antenna contact and put it aside. What does that contact do? On the video she does not show her replacing it. I have not yet done so yet the phone functions receiving a message. It is a bugger to replace [with arthritic fingers].
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi
I believe the contact is for grounding purposes
All you have to do to put it back on and align the hole with where the screw goes back in then plug your battery back in on top of the antenna
So the screw should go through the metal bit on the battery connector and go through the little metal loop on the antenna
If you need any more help just ask
Hopefully this helps
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
william heilman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 27
