Ga door naar hoofdinhoud
Uitgebracht in 2020. Modelnaam GeForce RTX™ 3060 Ti VENTUS 2X OC Grafische processor NVIDIA® GeForce RTX™ 3060 Ti Interface PCI Express® Gen 4 CUDA®-cores 4864 Kernfrequenties Boost: 1695 MHz Geheugensnelheid 14 Gbps Geheugen 8GB GDDR6 Geheugenbus 256-bit Uitgang.
Thermal Pad replacement thickness
Does anyone know the thickness of the thermal pads?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Unfortunately, I cannot find anything on the specific thickness of the thermal pad, but I did find an article on finding the best fit for your GPU. I'll link it here for your viewing, but I'll give you the spark-notes of it.
Ideally, you should use the thinnest thermal pad that you can with the device. Start with a 2mm thermal pad, and if it has an indentation from the heatsink go down a size of thickness. The material that you use also matters, as some materials dissipate heat better than others.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
João Fonseca zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 78
Altijd: 6,831
