Ga door naar hoofdinhoud
The B6 and B7 versions of the Volkswagen Passat are front-engine large family cars produced by Volkswagen, a German automaker. The B6 line of the Passat was produced between 2005 and 2010, and the B7 line was produced between 2010 and 2015 as a facelift of the B6 line.
20 Vragen Bekijk alle
Right tail light won’t work
So, I have a VW Passat B6 2007. My rear right side tail light, day time running light stays on for a few seconds before it turns off. Now I don’t find the solution, and trust me I have tried. When turned on it starts to blink and then it turns off, I tried to put 12V directly on to the light and it worked perfectly. Please Help
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
It could be a corroded or broken wire perhaps even lose wire
Make sure bulb is all the way in and turned and inside connections or contacts are not corroded
Was dit antwoord nuttig?
Voeg je antwoord toe
simonrk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 170
