Ga door naar hoofdinhoud
De zesde revisie van Apple voor de iPod Touch-reeks, uitgebracht in juli 2015.
Why isn't the power button working?
So recently I took apart my iPod Touch to replace the battery, which I did successfully and it works, but when I was replacing it and took out the motherboard because I thought that I had to. Now the connector is loose to the board, and when I manage to get it to stay in it is still loose. Does anyone know how to fix this?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi
My first (major)repair was one of these and I had this exact issue because it’s really annoying to blindly get connectors connected from behind
I find I you get the cable and remove the little bit of silver/grey tape fabrics stuff and extend the cable until it’s straight
Before you do that you need to get the logic/motherboard out and you can kind of flip it and connect it fairly easily
It’s a bit bad to explain but if you need any help just ask me in the comments and I can help you at every step of the way:-)
Hopefully this helps
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Sean Murphy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 258
