Ga door naar hoofdinhoud
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
368 Vragen Bekijk alle
Cpu fan running on full speed while starting up
I cleaned my old mac from dust, collected everything and the CPU FAN started working at full speed when the computer started. In the "Macs Fan Control" it showed zero fan speed, although everything was connected and checked
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Clearly you CPU fan has failed! iMac Intel 27" (Late 2009-Mid 2011) CPU Fan
iMac Intel 27" (Late 2009-Mid 2011) CPU Fan Afbeelding
Product
$24.99
Was dit antwoord nuttig?
Score 1
8 opmerkingen:
Only one solution to change it?
door
@?????? - The motor and/or the tach has failed.
You could take it out and check motors windings resistance and if applying some air flow to it the tach reports voltage. But in the end its' time for a new part.
door
forgot to say, i have 2 ssds, one installed at optical drive
door
@?????? - and that changes things?
door
@danj - He Might be saying that because it could affect the fans because of the thermal sensor for the SSDs
door
3 commentaren meer tonen
Voeg je antwoord toe
?????? zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 64
