Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
20 Vragen Bekijk alle
battery will not charge after water damage
So my iPhone 2g got rained on a week ago and it powered back on after i immersed it in rice but not too long afterwards the WiFi went off and turned grey in the settings, and so did the network. The phone lights up when connected to the computer or charger but it is stuck in low battery charging mood and wouldn't even charge or boot. I have taken the phone apart and i noticed that the battery is a little too soft for my liking. My question is how do i know if the battery is damaged? when i press the battery it feels like it melted. Is the battery rock hard when it is not damaged? Also how do i fix the issue of the WiFi and network signal not working. Any help will be greatly appreciated.
Thank you
Is dit een goede vraag?
3 opmerkingen
rice theory is a myth all you can do is immediately remove battery remove mother board and clean the board with isophrophyl alcohol best you can and hope for best
door
or if all is working it is still advisable to clean board with alcohol since I have seen water damaged devices work a whole day and the next day they are dead this is what a repair shop would do as a first step or they should anyways the alcohol not only cleans any sulfur and oxidized surfaces but also evaporates quickly
door
and ya a new battery goes without saying you will deff need to replace it..
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It's highly recommended to replace the battery after a water damage. Batteries don't really like being short circuited, it could be dangerous to continue using it. And it's cheap.
If you mean iPhone 1G (the one with aluminum back), you should get a battery like this one : [gekoppeld product ontbreekt of is uitgeschakeld: IF105-017]
If you mean iPhone 3G (actually the 2nd generation), you should get this battery : iPhone 3G Battery
Replace a 1150 mAh battery compatible with iPhone 3G and fix problems with charging and battery life. Afbeelding
Product
iPhone 3G Battery
$14.99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
josh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,494
