Ga door naar hoofdinhoud
A2116 / 2019 / 3,6 GHz quad-core i3, 3,0 GHz 6-core i5 of 3,2 GHz 6-core i7 processor. Uitgebracht op 19 maart 2019.
Can I replace the Fusion Hard drive with an SSD on a 2019 iMac? and...
Will it cause any issues with the way the existing Fusion flash blade recognises or communicates with the new SSD?
Is it necessary I buy and connect a Thermal Sensor?
Can I buy any SSD? or are there some which cause conflicts?
I appreciate any help.
Thank you
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
The blade SSD is used as a cache drive to the 2.5" HDD when the two are setup as a Fusion Drive set.
When you remove the HDD replacing it with a SSD you will sever the Fusion Drive so the Blade SSD will just sit unused. The first versions of Fusion Drive used a 1TB HDD and had a 32 GB SSD for the cache drive, after August 4 it had a 256 GB SSD.
If you have the larger blade SSD I would recommend reformatting making it the OS boot drive as the PCIe/NVMe interface is faster than the SATA III (6.0 Gb/s). Sadly the small 32 GB drive is not large enough to do much of anything.
Here's the guide you'll need to follow to replace the HDD: iMac Intel 21.5" 4K Retina-scherm 2019 Vervanging van de harde schijf
If you can I would upgrade the blade SSD to something larger 256 is a good size for writing and simple web use with the macOS on it. Going with 512 or larger offers a lot performance! Here's the guide for it iMac Intel 21.5" Retina 4K Display (2017) Blade SSD vervangen
Otherwise don't worry about the blade SSD, just let it sit unused if you go with the 2.5" SSD.
iMac Intel 21.5" Retina 4K Display (2017) Blade-SSD Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
1 - 3 hours
iMac Intel 21.5" Retina 4K Display 2019 Harde schijf Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
30 minutes - 1 hour
Was dit antwoord nuttig?
Voeg je antwoord toe
James Rice zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 463
