Motor stalls when it gets higher grass to cut
Motor stalls when cutting load increases and sometimes dies entirely. It can be restarted easily but is basically useless for mowing a lawn with more than an inch to be cut. Acts like it can no longer increase gas to engine when rpm decreases due to cutting load.
Is dit een goede vraag?
1 Opmerking
Grass should be cut about every 5 to 7 days depending on the amount of rainfall. For the healthiest lawn it is best to cut at the highest or next to the highest length. You may have two problems. One, you are not cutting it often enough or two, you have the mower setting too low and it is choking the motor and therefore causing it to shut down. You will have less problem with weeds if you cut it at the highest length because the sunlight will not penetrate the grass as easily to germinate the weed seeds present in your lawn.
door Wanda
