Ga door naar hoofdinhoud
De Xbox One X (model 1787) is de krachtige spelcomputer van Microsoft en is de opvolger van de Xbox One S. De Xbox One X werd uitgebracht op 7 november 2017.
Why wont my controller connect
My xbox controller keeps disconnecting. It can happen every 30 seconds or every 5 minutes. Ive also tried with other controllers and charged batteries. But no matter what i try controllers still disconnect.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi
I usually work on things other than Xbox’s but I do know after working on PlayStation controllers that there is usually a little hole on the back that you can insert a sewing needle into the back of and press and hold a Little button on the bottom of it to reset it,it usually takes about 10 seconds
This is what I find usually works in PlayStation controllers
Hopefully this helps
Was dit antwoord nuttig?
Score 2
@palehatter I agree with @hellomacos that resetting the controllers is a very good first step.
However, it's a bit odd that it happens with several controllers...?
I would start with resetting the controllers and also resetting controller settings on Xbox (I hope it's still possible, I haven't touched an Xbox since the release of the 360).
If those fail, take out the batteries and wait a couple of minutes.
Then plug the controller into the console with a cable, as this should also validate and update the controller firmware.
I believe the procedure to factory reset the Xbox One controller, is to press the Xbox button and the Menu button together, holding them down for aprox. 10 seconds. This should restart the controller with the factory settings.
Hope this helps :)
Score 2
Voeg je antwoord toe
Scott white zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 129
