Ga door naar hoofdinhoud
The Oculus Rift S is a PCVR headset with 6DOF tracking using cameras located on the headset itself.
Can I fix the tracking on the headset
my headset keeps loosing the tracking no matter how much light or dim or no light there is. It should work and it did in the past but not anymore, it holds the trackign for a short time then says "lost tracking" and it can't get the tracking back. Is there a way to fix this? so it can keep holding the tracking and not loose it a few min after
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Did a quick search and found 3+ pages similar to this one with possible solutions to your problem, if none work, give a holler.
Was dit antwoord nuttig?
Score 2
unfortuneltuy the tracking can get better but never as good as it was
Voeg je antwoord toe
mikkel hansen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 27
Altijd: 1,599
