Ga door naar hoofdinhoud
Repair guides and support for the first generation of Sony's RX100 high-end compact camera with a 20.2 MP sensor. The Sony Cyber-shot DSC-RX100 was released in June 2012.
How to fix viewfinder not staying down?
Camera fell leaving a dent on the top near the flash, as a result the viewfinder will not stay down. This results in having to use the viewfinder as opposed to the back screen when shooting.
Is dit een goede vraag?
1 Opmerking
Similar problem here. I once popped out the viewfinder and now it won't retract/kept locked in down position.
Did you find any solution for that problem?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
As a quick fix, you can use a rubber band to keep the viewfinder in. This covers slightly the back screen, but you should be able to still see enough.
I found a small independent repair shop. They opened the camera, and replaced the spring in the viewfinder. They told me it was rusty, due to excessive use in wet/damp conditions (could be well true, as I used the camera also during all sorts of hiking trips). It costs me only 60$, much less than the original Sony repair shop.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Dan Hernandez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 210
