Ga door naar hoofdinhoud
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
Is there a touch lcd controller board to repurpose screen?
I have this old, but in good condition iPad Mini. I also have a cracked screen Galaxy S8 that otherwise works fine. I'd like to reuse the touch display from the iPad Mini to create a DIY portable touch monitor that I can plug in this or future smartphones over USB Type C to basically have a smartphone powered tabled.
I've tried searching for controller boards for the LCD model from the teardown article (iPad Mini Wi-Fi Teardown), but to no success. Does anyone know if it's even possible to do this? Would it be possible to find one and ask the seller/manufacturer to put custom firmware on it? Being a Samsung display, I'm a bit surprised it's so hard to find, but it's also a very old device.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
It may be possible, but the dev and sample cost exceeds the value of the device many times over.
There are display controller debug boards for this model, but I don't think anyone has done any work of value to repurpose the touch panel.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thanks, I figured as much, just thought I'd ask. Thanks for all the quick feedback.
door
What board do you mean that supports the iPad mini?
door
Hi
I don’t think you am an mod it to be a separate display but you might be able to get a app to do that
Iv used some apps with my 15 macbook pro and I works decently well
Hopefully this answers your questions
If not please ask
Score 1
2 opmerkingen:
I've seen that, but I'm looking to do something like this: https://www.youtube.com/watch?v=DrqdHVeB... and figured I already had a perfectly good screen to use for the project. Having a universal interface like USB Type C would be ideal to be able to use it for any compatible device.
door
I can’t see the video you sent me because it’s unavailable
Iv seen people do it with intel iMacs because
They aren’t as locked down as iOS devices
Is far as I know
Apple locks down iOS devices so that they aren’t easily modified
You may be able to try and find a extension board like what they use on iMacs but I don’t think it will be easy
door
Voeg je antwoord toe
T Cortina zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 69
Altijd: 3,648
