Ga door naar hoofdinhoud
The Acer Chromebook 11 C732 is a Chromebook computer sold by Acer and are a part of the Acer Chromebook 11 Series.
6 Vragen Bekijk alle
How can I safely remove hot glue from the keyboard
A device came across my desk with hot glue under the keys. My guess is that the user had attempted to replace the keys that had fallen off. How can I safely remove hot glue without damaging the key switches? I'm using 91% Rubbing Alcohol but I'm having little success.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
use the heat gun man its safer
Was dit antwoord nuttig?
Score 3
Hi
This is a hard one but if you are careful,I have had success removing hot glue from delicate things using a soldering iron but you have to be really careful
Hopefully this helps
Score 2
2 opmerkingen:
Depending on how things go I might use this as a last resort. I'm gonna try using a heat gun on the lowest setting. Otherwise I want to see if there are any other methods.
door
Be very careful though using the hot air gun
Iv accidentally burned Apple Watch screens on their lowest setting with them
The reason why I said the soldering iron is because it’s much more controlled and isolated
door
Voeg je antwoord toe
Jacob Mehnert zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 208
