Ga door naar hoofdinhoud
Reparatie-, demontage- en probleemoplossingsinformatie voor de Steam Deck met LCD-scherm, een draagbare spelconsole gemaakt door Valve, uitgebracht op 25 februari 2022. Te herkennen aan modelnummer 1010.
B button catching and getting stuck on shell
Has anyone come up with a solution to fix this? I thought maybe replacing the buttons might work, but the only part you can buy right now is the button membrane, which doesn't help. The only solutions i've seen currently is to either put a piece of tape in between the button and shell so the button doesn't catch, or to open up the steam deck and sand down the inside of the b button hole so it's nice and smooth. Anyone had any luck with the sanding?
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
1 Antwoord
Here is the link to the teardown if that is the route you want to take: https://www.ifixit.com/News/57101/steam-...
I haven't done it on the Steam Deck but have for other devices. It is also worth a shot to make sure when putting it back together, that it is lining up properly.
-Warren-
Was dit antwoord nuttig?
Voeg je antwoord toe
Conner C zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 32
Altijd: 4,209
