Ipad restart loop after replacing parts.
I have an Ipad Air and i have fitted a new battery and digitiser for it. I decided to do a test of the ipad to see if the new battery and digitiser worked and while the ipad does turn on, it turns off shortly if I drop it from a small height of around a cm or so. It does not do this if i apply pressure to where the LED connector and digitiser connector shield is, is this a result of improperly fitting something or do I simply need to apply the digitiser adhesive and seal the iPad once and for all since that might apply enough pressure across the entire LED? It also gets stuck in a restart loop from time to time.
I also understand that the Ipad can turn itself off if something comes out of its place leading me to believe that the battery might somehow also be improperly fitted?
Is dit een goede vraag?
