Ga door naar hoofdinhoud
Touchscreen Intermittently Working, Screen Issue? Board Issue?
I did a search, but didn't see this particular problem listed.
I have an iPhone Xs (Model #A1920, Software Ver 15.4.1) that I bought about a year ago, refurbished, on BackMarket. Phone immediately went into an Otterbox with a screen protector. No cracks, no chips, no visible damage, and it hasn't been dropped in water or otherwise abused (at least not by me). It's pretty much in the same condition it was received in.
About 7 months after I bought it the screen developed an issue where it would randomly go unresponsive, and then just as randomly it would start working again. Here's a video I took of the issue back in December:
https://www.youtube.com/watch?v=SIImbKog...
I sent it in for a warranty repair, it came back working, but a few days later the issue was back.
I sent it back again, and it came back working, but about two weeks later the same problem occurred.
Sent it in a third time, and again, the issue came back after I'd had the phone for a few days. However, this time I dithered about sending it in a 4th time (I'm out about $60 in shipping and screen protectors at this point), and the issue kind of went away after about a week.
And it has worked flawlessly for about three months, but as of last week, the screen has been acting up again.
For example, there are times when I can tap the screen, while the phone is resting on a surface, and it will wake up; but if I pick the phone up and try to swipe up the screen will not respond. There are other times when I tap the screen and the screen stays black, until I lift it up; at which point it will wake but the screen won't respond to touch.
There have also been times where the screen will swipe up, and it will work for a few seconds (e.g. long enough to open an app) before freezing again. There are even times when it works for 20-30 seconds before freezing; which is usually just long enough to think I can accomplish something, and start trying to accomplish it, only to be thwarted partway through.
The periods of unresponsiveness can last for minutes, hours, or most of the day (i.e. most of the day means I have checked it periodically throughout the day, and each time it has been unresponsive).
Today, the screen stopped working a few times, but started working again within a few minutes, and has, for the most part, worked all day long.
Battery charge level does not seem to matter, temperature doesn't seem to matter, I've done a hard reset, set it up as a new phone, etc. I haven't been able to pin down any circumstance in which it works more/less consistently. Just kind of works or it doesn't as near as I can tell...
Only other thing that 'could' be related? The wake/sleep button on the right side of the phone doesn't work consistently. There have been times when I've had to press it multiple times to either wake/sleep the screen.
Trying to figure out what to look into to get the phone fixed. I don't want to dump a bunch of money into it (e.g. buy a screen and find out it's something else, or pay someone and have another botched repair job, etc.) unnecessarily.
Thoughts? Thanks.
Is dit een goede vraag?
2 opmerkingen
If that switch is bad, it might be the culprit, I'm only speculating here since I know android not apple but a bad power switch on an android can cause multiple problems. AND sometimes it is just a dirty switch which cleaning fixes. I'd look for a teardown guide for it and try cleansing the switch. You might try canned air on it first, with properly crossed fingers.
Demontage van de iPhone XS en XS Max
door
Thanks for the tip. Any little bit is more likely to help than hurt. @uchetil
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I would think that the repair shop you sent it to would have ruled out a faulty screen but this is the first thing you need to rule out. The iPhone XS is a doubled layer board with an interposer board between which consists of pads that allow the voltage and data signals to go from the top board to the bottom board. A common issue on all the X models is that if the phone has ever been dropped it can crack the solder pads to the interposer board and they can become oxidised. Since the touch connector is located on the bottom board it is likely the problem.
If this is the problem a good repair shop would split the boards and reball the pads and maybe run a jumper if the pad has come off completely. A dodgy repair shop will just reflow the board with hot air or a heating platform which will only be a temporary fix.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
To be honest, I think that they did replace the screen the second time I sent it in. When I first got the phone there was a small scratch on the lower lefthand corner of the screen, and while I'd have to take off the protector to verify, my recollection is that the second time I got it back the scratch wasn't there anymore.
That's kind of why I'm trying to make sure it isn't likely to be another issue. The whole point of buying a used phone was to save money, and sinking money into it kind of erodes that purpose.
door
Voeg je antwoord toe
Eric F Williams zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 422
