Ga door naar hoofdinhoud
Hinges how to replace
HI
I have followed a HowTo on tightening the screws to correct a loose screen that flops back. Unfortunately, even after removing the screen and tightening the screws I still have the problem.
My question is if I was to replace the screen do the hinges come with it and would this be a possible fix? albeit a rather costly solution.
My PC is a MacBook Air 13 early 2015 model. 8GB ram and 256SSD.
Regards,
Allan.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I think you're throwing the baby out with the bathwater needlessly!
Once you get the display physically off you can replace one hinge to see where that leads you MacBook Air 13" (Mid 2012-2017) Display LVDS Cable That might offer enough stiffness and it's not as difficult as replacing the other side. For reference take a look at what's involved to take the cover glass off in a MacBook Pro MacBook Pro 13" Unibody Mid 2010 Front Display Glass Replacement which is a similar process to disconnect the camera cable.
The other option which I think is a bit extreme is replacing the display assembly MacBook Air 13" (Mid 2013-2017) Display Assembly and the hinges are part of the assembly.
For either the process is the same MacBook Air 13" Early 2015 Display Assembly Replacement
Replace a display compatible with the model A1466 Mid 2013 to 2017 MacBook Air 13" laptop. Includes the 1440 x 900 LCD 13.3" screen, aluminum case and camera. Part #661-7475, 661-02397, 661-02505. Afbeelding
Product
$314.99
Replace a display LVDS cable with a damaged connector or torn cable compatible with a model A1466 13" MacBook Air from mid 2012 to 2017. Afbeelding
Product
$19.99
MacBook Pro 13" Unibody Mid 2010 Front Display Glass Afbeelding
Handleiding
Moeilijkheid:
Zeer moeilijk
4 hours
MacBook Air 13" Early 2015 Display Assembly Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
45 minutes - 2 hours
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks for the info, Dan.
After looking at the removing the glass option I've decided my screen looseness is not all that bad. :).
I have had the screen off which was simple enough. However as for the glass option I don't have all the equipment need to do it, and not to keen to use the heat gun.
Regards
Allan
door
@knightal - Changing out the LVDS cable (and its hinge) takes me about a 1/2 hour, replacing the camera cable (and its hinge) alone takes me a good two hours.
I still think replacing the LVDS cable is a good 1/2 step and not too costly.
The camera cable needs the heat gun treatment.
door
Known issue Display "falls back after 100°" is there a fix?
Voeg je antwoord toe
Allan Mearns zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 31
Altijd: 739
