Ga door naar hoofdinhoud
Released in Fall 2016, the second generation Kia Cadenza was redesigned by Peter Schreyer.
How do I fix the seat belt ribbon?
Seat belt is not being pulled back in
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If its not pulling in at all I would think it needs to be replaced. The mechanism is a complex little part that can even have a small charge that fires with the air bag to tighten the belt a little.
When you pull the belt all they way out dose it make the typical seat belt noise? Then its just all out sitting there with zero tension?
I had a belt that would retract slow or only 90% of the way; I washed the belt in hot water to make it more flexible, that helped a lot.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Arslan Khan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 219
