Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
How to fix bootlooping
how to fix iPhone 6 s plus boot looping I have this iPhone 6s plus that has a good battery and is stuck boot looping I was using it and it just froze and then I turned it off and then once I did this it just rebooted and now has been like this for a couple of hrs how do I fix this problem also the phone does this when unpluged so the battery should be good plus i tried a new one and it did not work
things i have tried
new battery
updating it
what else should i do
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It is hard to diagnose this problem over the internet. If this came across my desk here is what I would do. I know you have completed some of these steps.
·         Remove the logic board and install it in a known good housing including a known good screen and battery. (If it boots you know it’s a parts issue)
·         Take a diode measurement of the PP_VCC_MAIN line. (A partial short on the 6s plus can cause your issue)
·         Try an update.
·         Put some pressure on the CPU while booting.
·         Check the PP1V8 has correct voltage.
·         Replace the Tristar IC.
·         Check the logic eeprom.
·         Check Baseband PMU and CPU on the 6s plus if they are faulty it will produce your problem.
If the update you performed was successful with no errors I would be inclined to say that the NAND and CPU are okay but you would need to check the power rails on these in case there is a partial short.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
i found a crack in the logic board used a rubber band and that fixed it for a temporary use
door
Voeg je antwoord toe
keith_themuscovyduck zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 176
