Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Vragen Bekijk alle
Only upper part of the replaced screen is responsive to touch
Replaced the screen as per IFIXIT instructions. I need to enter phone PIN number on startup. I can only enter the digits 1, 2 and 3. The screen is unresponsive to anything below where these digits are displayed. I can't select 'cancel', 'delete' or any other digit on the screen. I had to put the cracked screen back and everything on the old screen works apart from the cracked glass. Is this an indication that the replacement part is faulty?
The cables connecting the display to the body appear to be fixed in place. They are not loose so I think they are fully seated.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If the connectors are properly seated on the new screen and you have tried the old screen again and touch works fine it will defiantly be a faulty screen. Return it for another one.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Farouq Taj zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 29
